Ke17 Sleeper Project
Thanks bud. :happy:
Deff see ya on GOR!
heheh thats ok
hell yeah it will be ace if I'm not on entry ill just tag lol
see ya
jimi
  • Replies 80
  • Views 47.1k
Update.....
Ok guys i did some work on the car tonight so i pulled the front wheels off cause the front brakes seized when trying to get it off the trailer :bash:
So after pulling the wheels off i found this...
After asking dad i found out he put a sway bar on. The calipers are ke30 but modified the rotors his not sure on but he thinks there sigma ????
Inside of bonnet
Engine bay... Or whats left :lolcry: This engine also has a set of extractors win :happy:
Edited by jimi91
Continued......
Rear view...
Another rear with 1inch and 7/8 exhaust...
Cockpit...
Boot.....
Fuel tank which is ke20 modified to suit and holds 10 gallons????....
Front seat mount broken after many years of hard work.....
From all these mods i have found that dad has done over the years i think this is getting technical ???? :hmm:
Anyway now i have to start buying parts and making some room to start sanding it back :blinks:
Love to hear ur words of wisdom :wink:
see ya guys
jimi
Looks like its been rather well treated before it became a real sleeper.
should get it stipped and soda blasted, may cost a bit more, but will be so worth the time saving and ya know ya get everything
looks like a good base good luck
Edited by MattyZ
hahhaha yeah it was last rego'd in 1996 and dad had it for a long time before that so it has been through alot lol :lolcry:
yeah ive been told to but a mate said its a waist of money cause it doesn't get the rust off so lots of paint stripper and glad rap will do the trick and save me $1500 to spend on engine and suspension :wink:
thanks guys
see ya
jimi
Ok guys got a ques for all of u i have a tin of paint called glasuit???? my ques is what kind of prim will i need to buy will i need a special one or a normal primer ???? would love for the advice and help
Sorry guys havent been able to do anything due to busy holidays and finishing of the rally car now :dance: but hopefully will start work in feb as i have some holidays!!!
see ya
jimi
see ya
jimi
it depends on the paint your using...
2pac will need a 2pac primer, acrylic will need an acrylic primer and so on and so on.
I'd look for the good parts of the body, rub them back and prime them. the bad parts will need to be cut and welded. Start working your way through, front to back or back to front.
BUT....
Don't even look at a top coat colour until you've located all the rust and either fixed if its bady bads or rust converter'd it if its not so bady bads.
Note that: rust converter doesn't last forever..... but either does steel.
Edited by GJM85
Would you be interested in selling the front apron parker/indicator lights?
BUT....
yeah i just thought id buy some primer now while i have some money :lolcry: but yeah I'm def going to strip and find all the bad bits
na sorry mate ill prob need all the spares i can get lol :lolcry: seeing how I'm a p plater and a young hoon as everyone keeps saying :glare:
see ya
jimi
  • 2 months later...
Update.....
Been looking around at different modules to run my coil over system!!! I found one which is cheap and is able to be modified if i upgrade the car :happy:
The system i found is called a Megasquirt 3!!!
They are cheap and can be bought as a package to build or pre made...
My ques is..... Will this system do the job and is it a good module to use ??????
see ya
jimi
Why do you want to go to a coil on plug setup ? what advantages do you think it will have ?
Not sure just want to do something different from a elec dissy and points i just like the idea so when someone goes what u running i can say coil over system :happy: , i think it will give me a greater spark all round and will be able to handle the higher rpm lol :lolcry:
see ya
jimi
An electronic dizzy with a decent coil, leads and plugs etc will hold more revs than what a K motor can handle.
My 41 year old 3k with a new electronic dizzy revs to 7400rpm then valve bounce kicks in. Also does 110mph.
hahahahha awesome i just like the idea and the thing is i want something different from everyone like how everyone puts a 4age in a ke70 i want to be and individual and do it different :happy:
Like if i was to build a ke70 id put a hayabusa turbo in it or mid mount a lexus v8 and race it :dance:
see ya
jimi
