4k S/c Retard
i need help retarding the dizzy on my 4k s/c
can i use a unit of a blown carbed dizzy
can't afford a $500 msd unit
are there other options :) :lol:
how do i lock it?
small dob of weld???
please don't take me to seriously but, I'm guessing you don't hook up the vacuume advance line and you losen the bolt that stops the dizzy turning/coming out so that you can set the timing advanced as far as you need.
will need timing light to set timing.
i don't think welding it will help.
welding fixes everything haha, if it ain't broke, weld it
I'm all for the jaycar programmable ignition, under $100 and fully programmable, can even use the old points to get a signal. It'll also let you run a 12V coil, heaps better than points any day of the week.
Jaycar HEI kit
There's a handset that can be used with it too, have a search, there's other ones there too that are cheaper.
Other option is megajolt, but it needs a custom crank sensor.
