May 14, 201016 yr comment_437270 so after buying my ke30 from andy h, a few weeks later my head started to leak water into my pots. after inspection i found a brand new head gasket and a minor surface crack in my head, but the crack had the appearance of one that had been there for years. the mechanic at API engines lonsdale agreed. it looks like the previous owner has obviously had troubles with the crack before then just put on a brand new head gasket to buy him 3 months or so and sold it to me under the impression the car was gold. The head has been welded and shaved by API engines, ive bought a new water pump (because the old one was going to give out soon), and new gaskets for everything. Ive also painted my head, rocker cover, and water pump in anodized red and am doing my pulleys in anodized blue later on. so now I'm at the point where i reasemble my engine. I have a torque wrench but i don't know what tension the head bolts have to be for a 5k help? Ps. one good thing that came from all this, is that i realized my head has been ported! Report
May 14, 201016 yr comment_437271 so after buying my ke30 from andy h, a few weeks later my head started to leak water into my pots. after inspection i found a brand new head gasket and a minor surface crack in my head, but the crack had the appearance of one that had been there for years. the mechanic at API engines lonsdale agreed. it looks like the previous owner has obviously had troubles with the crack before then just put on a brand new head gasket to buy him 3 months or so and sold it to me under the impression the car was gold. The head has been welded and shaved by API engines, ive bought a new water pump (because the old one was going to give out soon), and new gaskets for everything. Ive also painted my head, rocker cover, and water pump in anodized red and am doing my pulleys in anodized blue later on. so now I'm at the point where i reasemble my engine. I have a torque wrench but i don't know what tension the head bolts have to be for a 5k help? Ps. one good thing that came from all this, is that i realized my head has been ported! 66nm for the 4k head Report
May 14, 201016 yr Author comment_437272 you don't know the 5K? or is it universal between the k motors? Report
May 14, 201016 yr comment_437273 As you will be putting a new Head gasket on, it should state the correct torque and procedure on the packaging. Report
May 14, 201016 yr Author comment_437275 As you will be putting a new Head gasket on, it should state the correct torque and procedure on the packaging. nope, i couldnt order toyota genuine where i am, so i got an aftermarket one. Report
May 14, 201016 yr comment_437276 Strange. I have never used a Toyota Genuine one, and the one's I have used have without exception always had the torque info on them. Report
May 14, 201016 yr comment_437277 i think the 4k would be the same torque, make sure you torque them in sequence Edited May 14, 201016 yr by Evan G Report
May 14, 201016 yr comment_437278 The reason I say the above is because Monotorque gaskets used to have a different torque to factory. Report
May 14, 201016 yr Author comment_437280 i rang API and they gave me the specs, whats the sequence? start in the middle and work your way out? Report
May 14, 201016 yr comment_437292 Don't use the actual 5k head bolts, use some 3k or 4k ones. I can't remember the exact reason but the 5k ones are similar to 'torque to yeild' bolts and the threads can stretch. 3/4k ones don't. I find it a bit hard to believe you can't get a genuine 5k gasket through Toyota. Did you ask for a KM36 liteace HG or were you asking them for a '5k head gasket for a corolla'? If you said corolla thats where they may have got confused. We actually have a member here who works in a Toyota parts department in my home city. I'll PM you his username. Maybe try sending him a message and ask for the part number (as I know he knows what they are - He ordered me one 18 months ago) then contact your local Toyota parts department and tell them you want a P/N XXXXX. ;) And like I've told you before, if you want to boost this motor I would also recommend sourcing some ARP head studs for piece of mind. ;) Report
May 14, 201016 yr comment_437305 Strange. I have never used a Toyota Genuine one, and the one's I have used have without exception always had the torque info on them. somewhat offtopic, but when i did my 4age hadgasket the packaging had a torque spec (50-100-150nm...or something, 3 stages) but the 4age manual specifies a certain torque and then a certain spinning of the bolt. ie torque to 100nm, and then turn 90 degrees. i just went with the toyota manual specs i think. still going after 1yr, so must have been alright.... (ps numbers in this post don't mean anything, and should not be used as any reference) Report
May 14, 201016 yr comment_437306 This has most of the info you need!!! 5K_spec__s.pdf Dave, any spec's that has degrees in it (relating to bolts), the bolts are yield strength, which means they are suppose to be one use only!! Didn't think 4age's had yield strength bolts, mmm, interesting!!! Edited May 14, 201016 yr by TRD ke70 Report
May 14, 201016 yr comment_437320 Yeah they do have torque to yeild bolts TRD. Mate of mine was putting a new head gasket on a 4AGE once and was asking me about the "torque to XXnm, then add another 1/4 turn". ....however APR kits for 4A's are pretty easily attainable. ;) Report
