sliding.. Posted June 9, 2010 Report Posted June 9, 2010 my gear box is on the way out in my 1987 mr2. but i don't know what to replace it with. its got a 7afe in it so iis got the box from the 4age or 7afe and is there any others that will fit it with LSD. please help cheers people Quote
towe001 Posted June 12, 2010 Report Posted June 12, 2010 C52, E51 or E58. I don't remember which one of the "E" boxes had the LSD from factory, unless you've already gone the aftermarket LSD route. But if you pick up a gearbox from the fwd corolla your going to have to crack the box open to spin the shifters around so that i t can be used in the mr2 Quote
machg Posted June 12, 2010 Report Posted June 12, 2010 Should be a 4AGE engine, not a 7AFE, never heard of a 7AFE swap into an MR2. Never heard of spinning the shifters around to suit MR2s can you be more specific about what you do exactly? Quote
Johno Posted June 12, 2010 Report Posted June 12, 2010 (edited) I heard you can't use a FWD 4age Gearbox on a MR2 because the gearbox is reversed or something. EDIT: never mind.. Towe001 explained it better. Edited June 12, 2010 by Johno Quote
towe001 Posted June 12, 2010 Report Posted June 12, 2010 7age maybe :) Its not so much the shifter itself but the mechanism its the opposite way to how it is in a fwd http://www.ae92gts.com/ae92gts_trans.html http://www.ae92gts.com/ae92gts_trans_rb_1.html Quote
towe001 Posted June 12, 2010 Report Posted June 12, 2010 After a bit of a hunt though my collection of bookmarks and link and what not FWD Transmission Conversion for the MR2 Still want to give it a go ?? Quote
sliding.. Posted June 12, 2010 Author Report Posted June 12, 2010 After a bit of a hunt though my collection of bookmarks and link and what notFWD Transmission Conversion for the MR2 Still want to give it a go ?? yeah cheers mate ill look in to it. Quote
Karllos Posted June 12, 2010 Report Posted June 12, 2010 E58 has the stocko LSD however there is still 2 types it could be a torsion or clutch engage..... I helped valandor swap a 7AFE into his 2, ran an EMS stinger went well :) Karl. Quote
MRMOPARMAN Posted June 15, 2010 Report Posted June 15, 2010 not all E58's had LSD's, and they also had different driveshafts. so if you get one, make sure you get the driveshafts with it. they are real had to find seperate. if your playin with boxes, maybe try a 6 speed from an AE111, and put a kaaz LSD in it? Quote
