andy2004 Posted June 11, 2010 Report Share Posted June 11, 2010 (edited) hi all just wondering if anyone can help me out here i just bought an sx corolla and it has a small port engine only mod so far as i no is a pod filter.now when I'm driving say at 50 kms i put the foot down and it jolts then blasts in to its revving.kinda hard to explain its like when you do it to an automatic.my theory is its running to rich and its putting way to much fuel in when i plant the foot? anyone had a similar prob or may no the reason? Edited June 11, 2010 by andy2004 Quote Link to comment Share on other sites More sharing options...
seabiscuit Posted June 11, 2010 Report Share Posted June 11, 2010 If you're used to driving an auto then you need to get used to driving a manual. It is probably just flooding the engine at first because you're planting the foot and because a manual has a "direct" drive (whereas an automatic has what I'd describe as a power buffer), you feel the power or backing off of power at the wheels a lot more. Gradually put your foot down... It's just a waste of fuel to plant the foot straight away. Quote Link to comment Share on other sites More sharing options...
andy2004 Posted June 11, 2010 Author Report Share Posted June 11, 2010 If you're used to driving an auto then you need to get used to driving a manual. It is probably just flooding the engine at first because you're planting the foot and because a manual has a "direct" drive (whereas an automatic has what I'd describe as a power buffer), you feel the power or backing off of power at the wheels a lot more. Gradually put your foot down... It's just a waste of fuel to plant the foot straight away. if anything I'm not use to an automatic sorry. I'm not one to put the foot down just would see how the engine went if i did as most people do with new cars they just bought. it just paused for a bit but then cranked right in to it. but i just noticed goin out to my car before that it was idleing at 2 thousand rpm which is not right so now I'm stuck with the question how do you turn your idle down to 800rpm?? just new to this engine thats all Quote Link to comment Share on other sites More sharing options...
LittleRedSpirit Posted June 11, 2010 Report Share Posted June 11, 2010 (edited) if anything I'm not use to an automatic sorry. I'm not one to put the foot down just would see how the engine went if i did as most people do with new cars they just bought. it just paused for a bit but then cranked right in to it. but i just noticed goin out to my car before that it was idleing at 2 thousand rpm which is not right so now I'm stuck with the question how do you turn your idle down to 800rpm?? just new to this engine thats all Don't muck around on an internet forum. What you need is a scan tool and a decent mechanic. Most likely dead sensor or wire, which one, i can't say. Not likely anyone will be able to say categorically without running a few tests. Edited June 11, 2010 by LittleRedSpirit Quote Link to comment Share on other sites More sharing options...
Mitch-12 Posted June 11, 2010 Report Share Posted June 11, 2010 its the sudden amount of air speed lost when you plant it... when you open the throttle butterfly the airspeed drops motor in efficient the after a bit airspeed comes up and it goes good nothing to worry about all cars do it Quote Link to comment Share on other sites More sharing options...
Sam_Q Posted June 11, 2010 Report Share Posted June 11, 2010 sounds like something is wrong, I am with Redspirit get it profesionaly checked out. Get the timing done while your at it. Quote Link to comment Share on other sites More sharing options...
rob83ke70 Posted June 11, 2010 Report Share Posted June 11, 2010 sounds like you have a problem. when you put your foot down to wide open throttle it should immediately pick up and smoothly, with no hesitation or jerking. I'd reccommend taking it to a mechanic.... going to go out on a limb and say if you don't know a motor mechanic then take it to a toyota dealer.... probably take a LOT of time of the diagnostics by having information and experience.... make sure the pod filter is clean too!! I'm sick of seeing cars with k&n filters and pod filters that don't get looked after or maintained! 90% of the time you'd be better off with a factory air cleaner setup anyway (cold air and serviced properly). Robert. Quote Link to comment Share on other sites More sharing options...
andy2004 Posted June 11, 2010 Author Report Share Posted June 11, 2010 hey thanks guys yea i think that might have to be the case jus the guy before tryed playing around with it because it was sputtery and i said that usually happens when u water blast an engine with out covering up the filter and all ignition points etc.and he scratches his head and said opps. but owel i bought it so guess i took the risk. yea its a cheap filter so will get that replaced to. thanks for the info anyway guys Quote Link to comment Share on other sites More sharing options...
rob83ke70 Posted June 12, 2010 Report Share Posted June 12, 2010 if it happened after it was pressure washed then you need to reverse anything that has been played with so it is all back to how it was, remove the spark plug leads and possibly plugs too, and dry everything out!!! Robert. Quote Link to comment Share on other sites More sharing options...
