June 28, 201016 yr comment_447900 hey all i've got a ke70 thats in the build atm. I know that a 4age is pretty much a straight swap into a ke (using the crossmembers and all). I was just wondering if it was any harder doing a 3s beams motor and box swap into one? What would i need to get 3s crossmembers to fit in or would need to get some made up. If anyones got any info on this please let me know cheers. Report
June 28, 201016 yr comment_447904 http://www.rollaclub.com/board/index.php?showtopic=34556 Lo and behold, this link is itself also full of links. EDIT: Most important link is Billzillas AE86 conversion as that is reasonably comprehensive i.e. lots of photos. Edited June 28, 201016 yr by xmoht Report
June 28, 201016 yr comment_447930 your in sa go down and see Jay at buddyparts he has a beams in a ke70 Report
August 31, 201016 yr comment_464488 Another one has turned up here- http://z4.invisionfree.com/lexusaltezzaclu...;#entry11433563 Report
December 7, 20169 yr comment_707409 How did you go with this? Where did you get the kit to put beams into ke70? Report
