Sr20 Ke30
my bro should be home this arvo........... =)
they're commin'
Hey, i will be doin burnouts at AUTOFEST on the 3rd and 4th, come and check it out finished, and spin yarns. :thumbsup:
  • Replies 102
  • Views 79.6k
thanks man!
Yeh, it goes well with the stocko 120kw SR. The conversion was quite simple,there were a few probs as far as clearance goes, the tunnel fits great up to where the rola box used to end, but the sr box is much longer so the mid-tunnel has to be widened. This would be no worrys except this lands right on top of the front seat brace....bummer. cut and weld! other than that both crossmembers were real easy, :thumbsup:
TURBO HERE I COME!
So far... so DAMN good!
Please tell me you'll get the plates MIDORI =)
I love the color!
Engine mounts... what was the go there?
Keep us posted on the progress :thumbsup:
Edited by Tiger
u like the color? sweet! most people hate it. :sad: Its actually the stock rola color TOYOTA AJ "bright green". The mounts were really easy if u can weld... i just moved the stock mounts on the rola crossmember, changed the angles a bit and re-welded them. The g'box member was a just as easy, a bit of 25mm RHS is pretty much all u need. =) :wootjump: :thumbsup:
