August 21, 201016 yr comment_461376 So which is the one that rots out cooling systems in the wrong car?? Report
August 21, 201016 yr comment_461377 i belive the red stuff isnt the stuff were surpose to use in out 4k, there only used in systems with alloy radiators (i think) 4k allways green Report
August 21, 201016 yr Author comment_461381 Ah- and a Type B coolant?? I'm using the first one, the green concentrate, and looking at whats left in the bottle it must be very concentrated in the car! Report
August 21, 201016 yr comment_461494 Interesting point. Where running a rear mounted aluminium radiator on a KE30 with a 3k. What type should we be using ? Andy Report
August 22, 201016 yr comment_461564 basic rule of thumb: green does everything, red does only aluminium radiators. check each manufacturer's specific guidelines before using. red apparently lasts a lot longer. I don't think any of them last as long as they make out to be without having some sort of drama like water pumps or gaskets leaking. Robert. Report
