August 28, 201016 yr comment_463495 Here is what it looks like and what it sounds like Edited August 28, 201016 yr by Twinky Report
August 29, 201016 yr comment_463623 can i ask what kind of air filter that is and where you got it from?? Report
August 29, 201016 yr comment_463736 What sort of difference did the air filter mod give van? Did you just leave the top circle sealing against the filter top?? here is a pic (not my photo) that i edited carefully... I got the grinder out and cut around the ring (there is a rubber seal underneath so it seals well onto the filter still. Straight away it revved harder and pulled harded over 3000rpm. it also sounds great too.i played around with the a/f screw abit and i helped it again. worth doing for sure. costs $0. i took the 3 clips around the filter housings outside edge off too so they wouldn't rattle around. :P Edited August 29, 201016 yr by e70van Report
August 29, 201016 yr comment_463750 ^ and you can always grab a spare lid from the wreckers if you ever want to change it back :P Report
August 29, 201016 yr comment_463764 Great! I thought it would get rid of one bottleneck in the intake system. That would be the cheapest path to extra power ever! Report
October 6, 201015 yr Author comment_473844 havent been on here for a while, found a set of extractors and other bits and pieces for the 4k... thinking on a v6 ecotec conversion does anybody do conversion kits or know how to? Report
October 6, 201015 yr comment_473871 spend $300 on a 5k, then do same list of mods you've already said. where does one get a 5k for 300 bucks? Report
October 7, 201015 yr comment_474077 where does one get a 5k for 300 bucks? I got one out of Southport Auto Recyclers for 375 doi! So i'd say the wreckers.... Report
October 7, 201015 yr comment_474114 My 4K KE30 had all stock 4k, just pulled apart cleaned up and back together. Thermo Extractors into 2" system and a straight thru muffler. Went like the clappers to be honest. Wouldnt go ANYTHING over 2" exhaust. Even for the supercharged setup the exhaust shop only recommended 2.25" Go for a muffler and resonator. Was waaaayy too loud, police didnt like it quite as much as I did. Report
October 7, 201015 yr comment_474124 where is a good place to source a cam? what grind would you reccommend? yeah was going to take the head off and give it a clean up, and have been checking out ebay for a carby seems to be a few good buys on there. was going to machine the flywheel a bit too Your flywheel depends, more heavy it is more top end, the light more bottem end. Report
