4k Mods
Here is what it looks like
and what it sounds like
Edited by Twinky
  • Replies 33
  • Views 13.7k
my mushroom filter sounds better :blinks:
can i ask what kind of air filter that is and where you got it from??
What sort of difference did the air filter mod give van?
Did you just leave the top circle sealing against the filter top??
here is a pic (not my photo) that i edited carefully...
I got the grinder out and cut around the ring (there is a rubber seal underneath so it seals well onto the filter still.
Straight away it revved harder and pulled harded over 3000rpm. it also sounds great too.i played around with the a/f screw abit and i helped it again. worth doing for sure. costs $0. i took the 3 clips around the filter housings outside edge off too so they wouldn't rattle around. :P
Edited by e70van
i guess it would sound sick and no trouble from the cops!
^ and you can always grab a spare lid from the wreckers if you ever want to change it back :P
Great! I thought it would get rid of one bottleneck in the intake system. That would be the cheapest path to extra power ever!
havent been on here for a while, found a set of extractors and other bits and pieces for the 4k... thinking on a v6 ecotec conversion does anybody do conversion kits or know how to?
spend $300 on a 5k, then do same list of mods you've already said.
where does one get a 5k for 300 bucks?
I got one out of Southport Auto Recyclers for 375 doi! So i'd say the wreckers....
I paid $250.
My 4K KE30 had
all stock 4k, just pulled apart cleaned up and back together.
Thermo
Extractors into 2" system and a straight thru muffler.
Went like the clappers to be honest.
Wouldnt go ANYTHING over 2" exhaust. Even for the supercharged setup the exhaust shop only recommended 2.25"
Go for a muffler and resonator. Was waaaayy too loud, police didnt like it quite as much as I did.
where is a good place to source a cam? what grind would you reccommend? yeah was going to take the head off and give it a clean up, and have been checking out ebay for a carby seems to be a few good buys on there. was going to machine the flywheel a bit too
Your flywheel depends, more heavy it is more top end, the light more bottem end.
