September 9, 201016 yr Author comment_467309 na not seen it run.. plugs good had few sets.. rpm is good on lap top.. not checked map sensor will do tonite.. yea got comp 2.. cheers m8 Report
September 11, 201016 yr Author comment_467582 yea m8 has spark got it to fire up on 3 cyl last nite need to determine which 3 now and y they firing and others not Report
September 11, 201016 yr Author comment_467594 has anyone wired coils stock ignitor? how did u wire it jus firing order or paired 1+6 2+5 3+4? cheers Report
September 11, 201016 yr Author comment_467617 had spark wen tested last tested now coil 1 only coil receving signal checked wiring 2 ignitor for 10000000th time is ok then checked output from ecu to ignitor and was only sending signal 2 fire cylinder 1 no others... Report
September 11, 201016 yr Author comment_467633 he said was all there all good had base map wen bought it he just went through it all and said was sweet then wen didn work installed his base map that always uses on 1j cheers Report
September 11, 201016 yr Author comment_467662 considering getting ecu tested so can rule it out as seems no output from it is the fault.. as had 3 diff base tunes and all wires ok wen tested Report
September 11, 201016 yr comment_467683 That ecu doesn't have burnt igniter transistors does it? If you've triple checked everything, it might be worth opening the ecu to make sure it isn't toasty. Report
September 11, 201016 yr Author comment_467685 is what I'm thinking m8 man that b costy!! cos re checked so much dunno what else could be re did all comp 170psi good considering been sitting cheerr dylan Report
September 11, 201016 yr Author comment_467772 ok got spark at all 6 coils now... but no go at all man she a moody yota!!!!!!! Report
September 12, 201016 yr comment_467813 ok got spark at all 6 coils now... but no go at all man she a moody yota!!!!!!! Recheck the injector pulse. Report
September 12, 201016 yr Author comment_467821 yea m8 thats this morns mission dunno if they maybe blocked up again as ive been told they are very prone too blocked 2 were siezed wen i had them done few weeks back cheers Report
