  • Replies 106
been saying that ages now lol stumped.. earths at ecu ok power there.. pulse is there is random thing 2 me... tuner saying do full rewire from start again i don't think i have the know how 2 do it and dunno wats even left 2 do....
Not sure how the EMS are at voltage but the haltech ecu's don't fire under 12v, if you are pulling the plugs out and winding it over to check spark then the engine will be taking less power to wind over, leave the plugs in and throw a spare in number 1 lead.
has coil over plug 6x put power direct to inj loom made no diff.. earthed inj individually click was very evident.. added 2 wires to earth wire at ecu jus so earth was 110%... nothing.. is it possible the ecu is not earthing internally enough so doesn't let injector activate... anyone in perth got a 8860 installed willing to plug mine in to see if fires up on an already proved system?? carton 4 anyone who can!!
with the spark? yea m8 has spark..
Well try carby clean again, if it does not work then I suggest to get it looked at.
Fuel, spark & air should fire.
yea after manually earthing injectors it actually coughed 4 a second instead of jus cranking obviously cos fuel was in cylinder jus don't get y injectors wont work from pulse provided...
yea did carby clean wants 2 go dam injectors!!!!! is going 2 ovaboost 2morrow theyll prob fix in minutes lol...
man cars a pig atm now brakes wont bleed up needs master cyl rebuild and id say booster as leaking back into it! never ending!!! >|
