I Have So Much Luck, All Bad
Hi guys and girls, hope your having a better time
than we are. To start with about two months ago
we swapped the perfectly good 4k for what we
thought was an even better 7k.
On the way home from putting in the 7k the
alternator decide to give up. Not to much problem we
had a spare. Swapped alts but car was overheating.
Next day new thermostat. Still overheating
Next day new water pump. Still overheating
Next day thermo fan added. Still overheating.
Think for two days tried another thermostat No overheating
New prob, at mid revs motor chokes down. NO idea.
THen clutch gives up along with rear brakes.
Fix them and decide to add electric fuel pump for new carbs
Fuel pump doesn't work, brand new relay no good.
Fuel pump works motor doesn't turn over, remove starter
its stuffed. Fit rebuilt starter motor. Engine locks up.
And this is where we are. It seems with cooking the motor
we probably started the ball rolling but now it seems we
have dropped a rod, this is now becoming expensive.
To make matters worse 2 weeks ago under pressure
from the other half i disposed of our completly perfect
4k. Haven't even started about the probs with the MERCEDES
HOWS EVERYBODY ELSE DOING
:cool: :lol: :P
Edited by SLOTH Snr
Wish i was cruising round the panhandle.
It would be a lot less stressfull
Things were going great guns for you the other night when we caught up. Then all these problems in a matter of a week or two. Clutch and rear brakes.......sounds like Craig has been doing wheelies :cool:
How did you go fitting the fuel pump. No problems routing the fuel line through the floor?
So have you snapped a conrod? or Dropped a valve?
If the 7K is Cactus - I have a 3K down the back. Its in pieces and the bores have a bit of surface rust on them. All the pieces are there, but it would have to be rebuilt. Its yours if you want it.
Thanks for the offer Dazza. I'm sending the car to a
mates workshop tomorrow and he will let me know
just how serious. Running the fuel line was a breeze
after seeing yours. I will have to buy you a beer
if we go karting. Had enough of cars
sob sob sob sob sob sob sob sob sob sob sob
bad luck sucks.
hope it turns out for the better...
I've made money out of my coupe...
