November 18, 201015 yr comment_483056 Was wondering how hard it would be to use a supercharger/carb setup on my 3tc the supercharger is from a mr2 been looking for someone who has done it but found nothing. Thanks guys Report
November 18, 201015 yr Author comment_483059 Another question is i wanna use an electric fan on my 3tc any know what size fan they would use to keep it cool Report
November 18, 201015 yr comment_483062 12 inch fan. just do a suck threw system will be exacty the same as a suck threw sc setup on a k motor search boss Report
November 18, 201015 yr comment_483119 raw gas? suck through has the carby on the intake of the super/turbo charger. so your turbo is compressing air and fuel. i don't really like the idea....but it does work. Report
November 18, 201015 yr comment_483141 Makes two of us that don't really like the idea of a draw-through turbocharging. The only good thing about this style of turbo setup is the ease of doing it - just move the carby from near the motor to the other side of the turbo. That is between the air filter and turbo. Nothing else needs to be done, unless you feel like playing around with fuel mixtures to try and get it running even better. Downsides are, or can be, major headaches - lag time between giving the motor a boot full and the motor powering up can be painful at times. Have a google on it. And do the same with "Blow-through turbocharging" Bit harder to setup but its a lot better. Not as good as efi but still better. Report
November 18, 201015 yr comment_483142 And a quick search http://www.rollaclub.com/board/index.php?app=forums&module=forums§ion=attach&tid=21095 http://www.rollaclub.com/board/topic/21095-supercharged-3t-c-ke30/ Report
November 19, 201015 yr Author comment_483185 Ive been looking but still somewhat confused so i build a carb box seal it off turbo before the carb or after? an do i have to use some sort of fuel enrichment with draw through? thanks, James Report
November 19, 201015 yr Author comment_483187 Whats the deal with the red circle around it this setup looks easy enough Report
November 19, 201015 yr comment_483191 Air to water intercooler. Bit more complex to setup but i think the benefits of the setup, on a road/street car, outweigh that of an air to air intercooler setup. Report
November 19, 201015 yr Author comment_483199 ok so does that supercharged setup w/o the intercooler work the same with a turbo carb on the inlet intake on the outlet an do i have to use fuel enrichment of some sort of am i good with just a 2 barrel carby Report
November 19, 201015 yr Author comment_483201 an i can run an air intercooler on on this draw through setup Report
November 19, 201015 yr Author comment_483210 Another thing that has me puzzled is how do you start it when its turned off because the carb is so far from the manifold? an does this setup work the same with a turbo carb on the inlet? Report
November 19, 201015 yr comment_483212 an i can run an air intercooler on on this draw through setup I didn't even see the carby and its location till now. Having an intercooler like that can be done, but it should not be done. Another thing that has me puzzled is how do you start it when its turned off because the carb is so far from the manifold? an does this setup work the same with a turbo carb on the inlet? Basically winding the motor over till it kicks. Shouldn't take that long cause of the pools of fuel that'll be left behind after the motor is turned off. Think of the amount of fuel and its vapour that'll be sitting in the intercooler just waiting for a nice little backfire or something, it'll be like a bomb. Report
