November 29, 201015 yr comment_484915 hey guys/gals just wondering if it where possible to put a 5spd from a RA40 celica in a KE30 corolla is it a straight bolt in, have to change bell housings or it just wont fit any info would be great cheers Report
November 29, 201015 yr comment_484923 No dice. Ra40 5 speeds are a w50. Won't bolt up to the k motor without a k-w bell housing. I think they are hydraulic clutch too. Tailshaft is diffent. Report
November 29, 201015 yr comment_484924 No dice. Ra40 5 speeds are a w50. Won't bolt up to the k motor without a k-w bell housing. I think they are hydraulic clutch too. Tailshaft is diffent. Yes shaft spline is different, but they are still cable..... http://www.rollaclub.com/board/topic/12935-how-to-fit-a-w50-to-a-k-series-motor/ Report
November 29, 201015 yr comment_484925 By that i'm guessing you mean w50? Which afaik may or may not be hydraulic. Being W series and not K series it's not a straight bolt in and bellhousings wont fit, and output shaft on the box is 99% likely to be a different pattern/ size to that on your driveshaft. Easiest thing would be to get a box and compare. Or Just look around for K50. Cheers Jono edit: other beat me to it :lolcry: Edited November 29, 201015 yr by Jono.C Report
November 29, 201015 yr comment_484956 both my ra40s have had hydrolic clutchs... and they both had w55 box in them Report
November 29, 201015 yr comment_484957 both my ra40s have had hydrolic clutchs... and they both had w55 box in them Seems really odd to me, as every single ra40 manual I have ever seen features either a w50 or w40. I know you need a liteace housing off an L series gearbox to make it work from memory. May as well use the liteace clutch too while you are there. Should be cable aswell. Report
November 29, 201015 yr comment_484960 Seems really odd to me, as every single ra40 manual I have ever seen features either a w50 or w40. I know you need a liteace housing off an L series gearbox to make it work from memory. May as well use the liteace clutch too while you are there. Should be cable aswell. Yeah RA40's had W40/50. are you sure your's were 55's? is the gearbox case steel or alloy. And yes a W50 (in normal RA40 form) is hydraulic clutch, but as soon as you bolt the K-W bellhousing to it it becomes a cable operated box as the litace was still cable. Edited November 29, 201015 yr by Taz_Rx Report
