December 25, 201015 yr comment_490518 i don't have an engine crane and was after a way you guy's have removed an engine without using an engine crane, Report
December 25, 201015 yr comment_490526 take everything off piece by piece so its only the block left ? Report
December 25, 201015 yr comment_490528 Radiator out. Top radiator removable support out. Piece of chain. Long pole. Couple of strong mates. Three people are the minimum to carry out. Two to lift, one to guide. Report
December 25, 201015 yr comment_490535 two people can lift out a 3k with everything attached (inc gearbox /manifolds) she was heavy but! Report
December 25, 201015 yr comment_490543 where in melbourne are you,pm if you like, as if your not far away I can POSSIBLY get hold of a hoist from a mate and bring it over for the day,just depends if I can get in touch with him. Report
December 26, 201015 yr comment_490555 muscles matee This and a bike tie down wrapped around a support beam, I helped camerondownunder88 pull his out this way, I lifted the motor while he took the slack out of the tie down, repeat the process till it is high enough. Report
