February 13, 201115 yr comment_502624 can some one please help me!? I just removed my stock ae71 strut and control arm set up and replacing it with the xt130 LCA's, struts and brake set up, but am unsure if i needed adjustable camber tops, or if i could use the ae71 or xt130's? is that a noob question or what?? I have trial fitted the ae71 tops and it fouls the top of the corona spring retainer (as i was going to use corona springs with 1 coil cut out) and from what i can tell that wouldn't allow the strut to pivot when turning?...am i correct? so any info ASAP would be great! Edited February 13, 201115 yr by Twincam16seca Report
February 13, 201115 yr comment_502627 A few people have just left the ae71 spring, top spring hat thing, and the thing that you can see from in the bonnet (i can't remember what they call it, i call it the top thing). And the spring is ment to fit fine on the lower spring hat even though it is smaller than the coronas spring. Report
February 13, 201115 yr comment_502639 http://www.ke70.com/forum/index.php?showtopic=83 tech article about it Report
February 14, 201115 yr comment_502907 As above, use corolla top.spring hat and strut top. Also use corolla camber top or stock strut top. Are you using corona control arms or steering arms too? If so theres more u need to know about using them. If your in or close to brisbane happy to show you on my cars, both run this system :-) Report
February 15, 201115 yr Author comment_503206 As above, use corolla top.spring hat and strut top. Also use corolla camber top or stock strut top. Are you using corona control arms or steering arms too? If so theres more u need to know about using them. If your in or close to brisbane happy to show you on my cars, both run this system :-) cheers guys I'm using the corolla spring with a coil cut out to get the right height, the corolla strut top, corona LCA, disc and twin pot caliper, and the steering arm that bolts to the bottom of the shock. not sure if its the power steer arm as i haven't measured it. I had it wheel aligned today and i have -1deg camber! drives better, the extra info about the arms would be good! thanks! I'm in Adelaide though 'ella' Edited February 15, 201115 yr by Twincam16seca Report
