Hi guys recently had a full respray on my ke70 and know have to put everything back on. Just wondering what people reconmended for sealing up rear tail lights as original rubbers aren't in the best shape?
Also what do people use to stick back on the rubber stripping on the side of there cars?
Cheers Scott
Most of that foam you can buy is porous.. it isn't a going to be a good seal
It also stays wet for a long time, promoting a really good rusting situation.
I am not sure what the solution is, but I would be worried about using stick on foam for the above reasons.
Ok so now I'm taking the foam off coz I don't want my fresh paint rusting. Black silicone and pack it on sounds good, or I do have sikaflex but that stuff is the wow factor!
