hey. does any one know if the 1983 ke70 needs to both drine holes on chassie?? the ones right under the front two seats...
if that helps at all?
Only if it leaks....
or floats down Toowoomba's main street in a flood.
You should never get water inside. You 'd always be better to sponge it out after taking the carpets out and hit it with a heater if it got wet, so I don't know why the drain holes are there.
Wtf does that say the only words that make sense are the last ones about under the front seats!!!!
There are 6 big drain plugs in a xe7x two under the driver and passenger's feet, two under the rear passengers feet, and two under the rear seat, they shouldn't leak at all, and shouldn't need to be touched.
If they leak i'd suggest pulling the carpet out and cleaning the surfaces around them then running sillicone around the plugs to seal them, so they don't leak again
