sweet ke coupe Posted June 5, 2011 Report Posted June 5, 2011 hey guys just picked up a 5 speed box for my ke55 but has no shifter does anyone know if the shifter from the old 4 speed box will fit in? the 5 speed is also from a ke55 i was told thanks Quote
love ke70 Posted June 5, 2011 Report Posted June 5, 2011 give it a try, i would imagine it should Quote
TE278U Posted June 5, 2011 Report Posted June 5, 2011 i'M 99.9% sure that the shifters don't interchange between 4spd and 5spd. lockouts for reverse are different, and something else. I believe you can use a shifter from a t-50 on the k50 if that helps Quote
Drewby Posted June 5, 2011 Report Posted June 5, 2011 Hey mate 4 speed shifter definiteyl doe NOT fit - the plate that attaches the shifter to the box is a different size and the holes don't line up - a plate doesn't work either cos it throws off the "throw" on the shift. I've also read somewhere that there are a few different K50 levers as well... so you'll need to find one off the type of car you got your box from... good luck D Quote
ke70dave Posted June 6, 2011 Report Posted June 6, 2011 i'M 99.9% sure that the shifters don't interchange between 4spd and 5spd. lockouts for reverse are different, and something else. I believe you can use a shifter from a t-50 on the k50 if that helps i am under the impression that the above is correct. which means you can buy a short shifter for a t50 (reasonably readily available), and put it in your k50 :wink: Quote
philbey Posted June 6, 2011 Report Posted June 6, 2011 Hmm that's an interesting option the T50 thing. There are two K50 boxes, can we confirm they are the same shifter between them (ke70 5 speed and KE55 5 speed) Quote
kickn5k Posted June 6, 2011 Report Posted June 6, 2011 Hmm that's an interesting option the T50 thing. There are two K50 boxes, can we confirm they are the same shifter between them (ke70 5 speed and KE55 5 speed) I've got my ke55 k50 out at the moment and I have a ke70 one aswell I'll check this arvo when I get home. Stu. Quote
sweet ke coupe Posted June 6, 2011 Author Report Posted June 6, 2011 thanks guys looks like i have a few options which is great Quote
kickn5k Posted June 6, 2011 Report Posted June 6, 2011 I've got my ke55 k50 out at the moment and I have a ke70 one aswell I'll check this arvo when I get home. Stu. Just checked the ke-55 shifter in the ke-70 extension housing and it's no go!!!! The ksev shifter plate is shorter front to back. can't take a photo either tonight as the lights in the shed just died. Stu. Quote
