Anyone got a pinout /el.drawing of a 7KE ECU ?
Was hoping for a bit more than whats in the FAQ
Edited by tojo2
:hmm: interesting
Just had a look at the pdf i have and there's no mention of a ecu for a auto.
If you come across one would you be able to throw a copy my way and i'll see about throwing it up on the FAQ
On initial search on partsnumber it showed upp as a auto ecu so I assumed they were different. Your comment
make me check ECU numbers for auto and manual and yes, they are the same.
Thanks for clearing that upp. Deleted the auto comment in first post.
So I'm after a pinout / drawing or manual of any 7KE ecu
Here you go
7KE-manual.pdf
Thank you. Belive thats same as in the faq. Is that all there is?
Was hoping for something a bit more decifered like
whats VC, VTA, PIM, IGT
,IGF , NE , #10 and so on.
Any idea if these ECUs have start block with coded key?
CAUTION. All info here is assumptions
So here`s what I'm thinking so far. Open for suggestions :rolls:
Plug E5
Pin 2 +Batt battery fused permanent +feed
Pin 4 FC Circiut opening relay (fuel pump)
Pin 8 NSW Newtral switch for autos
Pin 9 +B Ignition on +
Pin 10 W Check engine light
Pin 13 SPD Pulses from car speedo
Plug E4
Pin 2 TE1 Check Connector (diagnostic)
Pin 3 THW Engine coolant temp
Pin 4 PIM Manifold Pressure Vacuum sensor
Pin 5 THA Intake airtemp sensor
Pin 6 IGT Ignitor "2" Ignition signal
Pin 8 IGF Ignitor "1" Ignitor confirmation signal
Pin 9 NE Dizzy Crank pos sensor
Pin 10 VAF Variable resistor (if no cat)4-6K
Pin 11 STA Starter Running
Pin 12 Injector feed
Pin 13 Injector ground
Pin 14 RSD Rotary solinoid on TB- (idle speed)
Pin 16 Grounds
Pin 17 VTA Throttle Pos sensor
Pin 18 VC Vacuum sensor + tps
Pin 21 NE Dizzy Crank pos sensor
Pin 24 grounds
Edited by tojo2
  • Like 1
I know what your after. Its the circuit diagram of the ECU and its sensors etc.
The manual i have doesn't have it as such, but it does cover the pinouts on the ECU and the sensors.
Its the full workshop manual for the 7k, its about 52meg in size. Can see about emailing it to you if you want it.
  • Like 1
If you pull the cover off the ECU, it should have it marked on the board, O2!!
Cheers, will check and update when I recive it.
"Pin 5 THA Intake airtemp sensor" was also missing from the terminal pinout.
