Ruff Idoling Issues
Hey all
A friend i know has an 83 Corona - 3 speed auto - stock as a brick block.
Hes been having this problem - its idoling very ruff - liturally.
Any idea whats cauzing this? - why would it just start to happen all of a sudden?
Oh and when it rains - EVERY TIME - the car loozes 3/4 Of its oil - even tho its under cover -
What The !!?!
Thanks lol
Teddy
rough. idle. spelling people!
let's see what i can pull out my ass in under a minute
- different fuel
- clogged idle jet
- carburettor idle circuit out of tune
- timing out of tune
- emissions system broken or out of tune
- vacuum leak
- head needs recondition
- excessive piston ring blowby
- timing chain/belt worn
wow - ok, what would be a good way to diagnose what's the problem - pin point it? or would that require a mechanic to look at it?
Oh somting i didnt add in the first post - he says the car actually runs Better[\B] now wile its moving (at speed) !! - Ahh, the poor old corona, neva got the attention like the corolla - the odd child out :|
I had 2 seperate issues with my rolla and its rough idling.
1st problem was a leaking manifold gasket. Was loosing compression to the number 4 cylinder.
2nd problem was a loose rocker arm on top of the f@$king no# 4cylinder (its a curse that hole in the block) cause the inlet valve to not seal properly.
Just some other thoughts to ponder.
