MattyZ Posted August 5, 2011 Report Share Posted August 5, 2011 Hey guys I'm in the process of stripping my celica back to bare metal and was wondering if there was a product to remove that underbody tar/rubber thats found in inner arches and underneath, wire wheel just clogs up and linisher just melts the tar and screws the disk. any ideas? that can take the pain and time of it away. Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted August 5, 2011 Report Share Posted August 5, 2011 Dry ice like sound deadner? Prob hard to hold it on there though Quote Link to comment Share on other sites More sharing options...
oh what a nissan feeling! Posted August 5, 2011 Report Share Posted August 5, 2011 I have found that cos its so old, if you get a start on it, it mostly falls off. Your sillycar must have had a good life. As reed mentioned, dry ice is the known cure, put it on the inside of the car and wait for it to have an effect underneath? Ive never tried that btw. The other option is a butter knife and a whole lot of persistance. Quote Link to comment Share on other sites More sharing options...
MattyZ Posted August 6, 2011 Author Report Share Posted August 6, 2011 ohh its had a rough life has its fair share of rust probably more than most would consider salvagable but, i like a challenge and in the end it will all be worth it. cheers for the ideas, ill have a play and what ever result works best or worst ill let you guys know. keep the ideas flowin too people the more the merrier. Quote Link to comment Share on other sites More sharing options...
JJT036 Posted August 6, 2011 Report Share Posted August 6, 2011 Hey There is a 3m product called a CLEAN & STRIP DISC its a plastic wheel looks week as piss but will do the job fine you will have to get it from a good auto paint supplies store Cheers Woz Quote Link to comment Share on other sites More sharing options...
azza001 Posted August 7, 2011 Report Share Posted August 7, 2011 Heat gun (or hair dryer, same effect) and a bbq scraper for the big area's and flat blade screw drivers for the tight spots. Any flat balde utensil. That's we what used anyway, a heat gun is preferable because it gets hot fairly quickly, but just basically heat it till it starts to go soft or melt and it should just scrape of. Quote Link to comment Share on other sites More sharing options...
tojo2 Posted August 11, 2011 Report Share Posted August 11, 2011 kerosine , steam (hot water), kero, steam, kero, steam ..... Quote Link to comment Share on other sites More sharing options...
