Negative Ninja Posted August 30, 2011 Report Share Posted August 30, 2011 Hi guys can someone please help me. I have had a bit of a look around the site but can't find what I need. Can someone please tell me how do I take the strut tops off my KE70 front struts. I have tried unbolting it when on the car and off the car. All that happens is it spins. So I figure either their not meant to come off or I'm a little dim. Please help. Quote Link to comment Share on other sites More sharing options...
7shades Posted August 30, 2011 Report Share Posted August 30, 2011 Rattle gun. Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted August 30, 2011 Report Share Posted August 30, 2011 Rattle gun is best, but if not, try wrapping a strip of rag around the strut shaft several times then anchor it with a screwdriver. If you don't want that shock just grab it with a plumber's wrench. The strut top is meant to have a flat in the shaft hole that should stop it turning. Is your one ripped out? Quote Link to comment Share on other sites More sharing options...
snot35 Posted August 30, 2011 Report Share Posted August 30, 2011 I'm going through the same dilemma at the moment, it's not yet solved :) Not all makes actually have the flat in my experience. Quote Link to comment Share on other sites More sharing options...
Twinky Posted August 30, 2011 Report Share Posted August 30, 2011 Get some multigrips, vice jaws basically anything you can tighten over the shaft. Get some rubber strip and place between the jaws and the strut. That way you have plentiful grip and no damage done to the shock. Quote Link to comment Share on other sites More sharing options...
philbey Posted August 30, 2011 Report Share Posted August 30, 2011 I used a rattle gun with a piece of bike tyres wrapped around the shaft. You can grab it nice and firm, the friction with the rubber is high and it prevents damage. Check 3rd photo here. rollaclub.com/faq/index.php?title=Lowering_KE1x_Front_using_KE2x_parts Quote Link to comment Share on other sites More sharing options...
Old fella Posted August 31, 2011 Report Share Posted August 31, 2011 Angle grinder.....MWAHAHAHAA. No seriously, if you`ve got enough of the threaded bit at the top visible, use an angle grinder to carefilly cut a couple of flats and then use a shifting spanner to hold it while yo take the top nut off. Sounds rough but it does work. Cheers. Quote Link to comment Share on other sites More sharing options...
clarkz Posted August 31, 2011 Report Share Posted August 31, 2011 i did mine the other day with a ratchet and my hand holding the shaft while it was out of the car! are they usually really that difficult? Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted August 31, 2011 Report Share Posted August 31, 2011 are they usually really that difficult? I'm afraid so, yours were described as "loose". Most mechanics/fitters seem to think "as tight as possible" is the correct torque. We have a little 6"x6" rubber grip-net in the kitchen for jar lids. Brilliant for this sort of problem. Quote Link to comment Share on other sites More sharing options...
clarkz Posted August 31, 2011 Report Share Posted August 31, 2011 lol ill keep that in mind when i try to do the other ones then! Quote Link to comment Share on other sites More sharing options...
snot35 Posted August 31, 2011 Report Share Posted August 31, 2011 Yeah, I'm not getting anywhere with the vice grips and bike tyre. Damn it! :/ This is turning into a saga. The top perches do seem to have holes for some sort of over sized pin wrench and there does appear to be flats, might try that next. Quote Link to comment Share on other sites More sharing options...
Crowie55 Posted August 31, 2011 Report Share Posted August 31, 2011 If you don't have access to a rattle gun try this: rubber around shaft, strong multi-grips around rubber, pipe on each handle of multi-grips, squeeze gently together as you'll have lots of pressure on them with the added handle length. get your socket and put another pipe on the end of that and bam! loosen those bolts up with your pinky. Quote Link to comment Share on other sites More sharing options...
snot35 Posted August 31, 2011 Report Share Posted August 31, 2011 You know what? I would have thought of that eventually! But you've probably saved me a week ;) Thanks for the tip!! Quote Link to comment Share on other sites More sharing options...
snot35 Posted September 1, 2011 Report Share Posted September 1, 2011 No dice with the pipes, damnit! I suspect my multigrips are a little too cheap and spindly. I also suspect the bolts were put on with a rattle gun! :P Quote Link to comment Share on other sites More sharing options...
Crowie55 Posted September 1, 2011 Report Share Posted September 1, 2011 WD40/inox the bolts and longer poles and more force!!!! that's about it for my advice, other than that you'll have to source a rattle gun. Cheers, Crowie. Quote Link to comment Share on other sites More sharing options...
