CommonhoreSlayer Posted September 16, 2011 Report Share Posted September 16, 2011 I'm getting frustrated with this 4age running pig rich can't seem to solve the problem was wondering if A aftermarket ecu that i could programe the a/f mix on would resolve the issue? has anyone put a megasquirt on a 4age Quote Link to comment Share on other sites More sharing options...
towe001 Posted September 16, 2011 Report Share Posted September 16, 2011 http://www.msruns.com/viewforum.php?f=89&sid=4e693e8c8b246cce3f249d279f614de3 Whats the cold start injector like ? Sometimes it can develop a leak making the thing run rich. Next on the list is the vacuum line to the MAP sensor. If the hose is broken it'll make the sensor think there's more air so it'll pump up the fuel. Next one would be the o2 sensor, it'll pump the fuel up if it thinks the motors running lean. Quote Link to comment Share on other sites More sharing options...
CommonhoreSlayer Posted September 16, 2011 Author Report Share Posted September 16, 2011 so rich that it stalls when put under load and fuel is coming out the exhoust Quote Link to comment Share on other sites More sharing options...
ae824ate Posted September 16, 2011 Report Share Posted September 16, 2011 so rich that it stalls when put under load and fuel is coming out the exhoust Fuel coming out of the exhaust?? Are you having alot of detonation of unburnt fuel in the exhaust? Banging, popping spitting and farting? Something must be super duper wrong if you are having problems as bad as you say. Quote Link to comment Share on other sites More sharing options...
t18drifts Posted September 16, 2011 Report Share Posted September 16, 2011 yeah itll stall on start up or under load on lots of white smoke will come out the intake Quote Link to comment Share on other sites More sharing options...
Damon550 Posted September 17, 2011 Report Share Posted September 17, 2011 is it bigport or otherwise and what injectors have you got? Quote Link to comment Share on other sites More sharing options...
t18drifts Posted September 17, 2011 Report Share Posted September 17, 2011 its a big port Quote Link to comment Share on other sites More sharing options...
philbey Posted September 22, 2011 Report Share Posted September 22, 2011 Forgive my prying question, but have you had it tuned, by someone qualified? On a dyno? Quote Link to comment Share on other sites More sharing options...
ke70dave Posted September 22, 2011 Report Share Posted September 22, 2011 philby i think what he is asking is "i can't get my engine to run on a stock ecu, will an aftermarket ecu make it easier" using only the knowledge ive gained about you in this thread, the answer is no. no it wouldnt. it would meerly make it infinitly more complicated and less likely to ever work. Quote Link to comment Share on other sites More sharing options...
