I'm running a Sr in a corona but all i need to know is what tailshaft to get so i can but the rear yoke off for a custom tailshaft to be made :) also i believe that the diff i hav is out of a celiba but i know what model! So all help would be appreciated :)
Also rt132 coronas and some rt104 coronas,much cheaper to buy corona parts than celica parts .As they don't hit ching key on there cash register :rolls: .
Even though they are the same parts bloody wollys :lolcry:
rob
S series are also found in ke70 vans. you just need a flange that is 55mm square bolt pattern and 38mm (IIRC) center bore.
Forgot to mention, make sure it isn't a staked uni shaft as you have to pay a lot more to have the uni removed.
Edited by Trev
