April 28, 201214 yr comment_600384 For this i used a broken VT Commodore window regulator which wasn't as good as the VR commodore motors i used in my car as the VR motors used normal bolts and the holes lined up easier you also have to reverse the motors passager VT/VR motor to driver side and drivers side VT/VR motor to passager. BROKEN VT REGULATOR REMOVE SCREWS TO MOTOR STANDARD KE30 WINDOW REGULATOR REMOVE SPRING CENTER PUNCH AND DRILL 3 PINS HOLDING WINDER WITH 6MM DRILLBIT CUT OFF GUARD ALIGN GEARS TO CENTER TO REGULATOR MEASURE YOUR BRACKETS ON 2INCH WIDE GALV DRILL HOLES 4.5MM FOR SCREWS AND POP RIVETS POP RIVET AND SCREW BRACKETS FINISHED Report
June 2, 201214 yr Author comment_607457 sorry it took so long to post this video been busy with other projects http://www.youtube.com/watch?v=eqmxzMBm6Cw&feature=youtu.be Report
December 2, 201213 yr comment_638455 Hi. Great effort. Have you encountered any issues with fouling of the window on the motor? Report
January 6, 201313 yr Author comment_642565 hay sorry for the late reply i did have a slight fouling issue by 2mm so i jimmied the motor over in the door fixed the problem and didnt damage anything. i now have to remove the passanger side motor as some dirty person tried unsucessfully to break in to my car but hoping for just a busted wire. i couldnt see why it wouldnt work with a ke70 but don't have one to try it on so i don't know.. Report
