May 30, 201214 yr comment_606924 Hi does any one know what the running temperature for a 4k i am trying to set up my thermo fan the fan switch is set at 91c closed and 95c i got the temp gauge up to 3/4 and that was only 80c. Any help would be helpful Report
May 30, 201214 yr comment_606927 82 deg C or 180 deg F, sounds like something is causing your engine to run hot, check your thermostat and radiator, cheers! Report
May 30, 201214 yr Author comment_606929 The new thermostate from toyota starts opening at 88 and fully opeb at 100 and it was spot on when i checked it Report
May 30, 201214 yr comment_606931 The new thermostate from toyota starts opening at 88 and fully opeb at 100 and it was spot on when i checked it sounds like the wrong one then. Report
May 31, 201214 yr comment_607168 The new thermostate from toyota starts opening at 88 and fully opeb at 100 and it was spot on when i checked it mmmmmm :hmm: , yeah reed is right, that is a little too high, all the aftermarket ones i buy usually start to open at 82 deg C, sounds like you were supplied with the wrong part. Report
May 31, 201214 yr comment_607177 where did you put the temp sender for your new fan controller? Edited May 31, 201214 yr by ke70dave Report
May 31, 201214 yr comment_607197 my thermostat opens around 85 degrees from dead cold. then stays at 80 and doesnt move Report
