Efi Can't Find One Any Where
Got a 5 k going in the ke25,, got the supercharger and manual pretty much ready to go,
Don't Want to run the carby with Set up tho would prefer efi..
Can anyone point me in the right direction
cheers guys, with that ebay one what else will i need to buy for it,, I'm not much with the efi side of things... lol
Honestly I don't know what I'm looking at
I suggest you really research what you are about to undertake and know what it is you are getting yourself into otherwise this could
be an expensive project that does not get finished.
Here are some things to consider:
New fuel system (pump,regulator,lines,surge tank, lift pump)
New ECU (all wiring and sensors associated with the ECU)
EFI ECU trigger system (new units can take Points/Hall/Reluctor/Optical)
Tuning of said ECU
While the list is short the work effort required is long.
Have a think about each of those points and how you would go about dealing with them, then add up the cost.
I converted mine to EFI and it cost me just over $600 for parts (sensors,wiring,fuel lines,pumps etc)
I did all of the work myself and then palmed it off to the tuner for another $500 for a short day on the dyno.
That is also on the cheap side because I've still got a few bugs to iron out. I could pay another $500 to get it spot on but I won't at this stage.
I would say that I know what I am doing, I'm no expert but I got it done and it was a large effort on my part.
By the sounds of it you have no clue, not even noticing that the throttle body is missing in that ebay link.
You may be able to find a complete kit if you just wait it out or have a really good search around your local wreckers.
In the mean time have a good read about EFI and all associated parts so that you don't dig yourself a money pit.
Have a look at my build
http://www.rollaclub.com/board/topic/41380-twinkys-old-fart/
Lol I actually know the bloke selling that in the ebay link, he lives in Adelaide.
If there is anything worth knowing about corollas and engines he knows it.
