74coupe Posted June 11, 2012 Report Posted June 11, 2012 Hey guys, realised I've been clogging up here with constant questions as I have really no idea and I'm now to this side of motoring as I've o ly really worked on c Vh, vk and eh, hz holdens.. So if I post the questions here from now on hopefully it won't be as annoying :) Quote
74coupe Posted June 11, 2012 Author Report Posted June 11, 2012 To start it off New diff.. I would like a LSD diff to suit my car as I have a 5k supercharger with a manual going in it.. I would also like to do the diff gears .. But!! Keep stock wheels* on it ( same as front) so hubs and stud patterns.. Quote
coln72 Posted June 11, 2012 Report Posted June 11, 2012 mmmmmmmmm LSD, stronger diff, stock wheels........... Only possibility I can think of is early RX7's or maybe RX3. Early bolt pattern and I guess that LSD's would be available but cost is going to be a killer for the conversion. Easier to convert to the later bolt pattern and source suitable steelies from another Toyota/Nissan/Mrbitchy. But even then converting a Skyline/Hilux/Celica diff isn't going to be cheap. Quote
74coupe Posted June 11, 2012 Author Report Posted June 11, 2012 Yeah man I know.. But I will eventually be tricking her with a ca18det so it will have to be done one day.. I would just like to keep the same wheels on her for that sleeper/granny look.. And not really too keen on welding the diff.. And I would like to do the diff gears so I won't have a vet high top speed but will be fun for what I want, Quote
styler Posted June 11, 2012 Report Posted June 11, 2012 ke25 is not easy for lsd options, almost all options are cut down diffs with resplined axles. Quote
74coupe Posted June 11, 2012 Author Report Posted June 11, 2012 Yeah ive kinda expected that lol but will prob cost a grand or so won't it, to have it in mine? But wouldn't mind a cheaper option lol Quote
74coupe Posted June 12, 2012 Author Report Posted June 12, 2012 decided to drop 2 inch around for time being.. just front springs i can get that are 2 inch and the blocks 2 inch for what i can afford. will be done once roady is done, then ill be ripping out the motor and re spraying the engine bay, and getting the new 5k and charger ready, and have the motor as clean as i can get her for a k motor.. she is looking a bit worse for ware at the moment lol... what sort of box is best used for the carby when i do the charger, i noticed some people have some big black ones for there blow through systems on the turbos.. are they custom or not? Quote
74coupe Posted June 14, 2012 Author Report Posted June 14, 2012 Buyin lowering blocks this week, the bloke asked me if it's 25mm pin??? Wtf is that. Lol Quote
coln72 Posted June 14, 2012 Report Posted June 14, 2012 centre bolt or pin that locates the diff on the springs. Quote
parrot Posted June 14, 2012 Report Posted June 14, 2012 My turn for a question now. What is that sticker on the rear window? Quote
74coupe Posted June 14, 2012 Author Report Posted June 14, 2012 Cheers coln72 Which sticker?? I have a "go wide" sticker for shots n gigs from mates Audi when he put spacers in lol A d the other one is the dealer sticker for 1974 Quote
74coupe Posted June 14, 2012 Author Report Posted June 14, 2012 Any one know what the ke25 would be?? Lol Quote
parrot Posted June 15, 2012 Report Posted June 15, 2012 Le mans motors I absolutely HAVE to get a photo of that sticker!! Not sure where you live, but would be keen to pop round at some stage, or perhaps catch you at Winterfest? I won't get there till about lunchtime though Quote
