June 14, 201214 yr comment_609789 Hi all, Very new to this. I have a 1979 KE55 sedan in great condition, it runs the standard 4k-c(149,000km) and 4speed box. I am looking to upgrade to a 5k with a 5speed gearbox, i have a few questions regarding this conversion. I am on my red P Plates in NSW am I restricted to conveting the engine? Is the engine hard to convert regarding mounts, diffs, gearbox ect...? What 5speed gearbox options do i have? and any other tips and ideas you could give me? I have done a bit of research so far and I'm just gathering ideas. So all help and idea's are welcomed. accidentally posted this topic in engine conversions aswell... sorry for that! lol Thanks heaps. Regards Nathan Report
June 14, 201214 yr comment_609792 I am on my red P Plates in NSW am I restricted to conveting the engine? Probably yes but 5k looks the same as what your 4k did so wouldn't be obvious. Is the engine hard to convert regarding mounts, diffs, gearbox ect...? All a bolt in conversion if you went for a 7k however I belive the sump requires modding, but if you keep it simple with a 5k its all bolt in. What 5speed gearbox options do i have? Your 4 speed will bolt up and then any 5 speed for a k series engine will bolt on. and any other tips and ideas you could give me? Just take your time and do everything properly then maybe think about suspension upgrades. Report
June 14, 201214 yr comment_609795 ^ Pretty much what he said. But remember, You'll need a new tailshaft from a manual version. Also, depending on what 5 speed gearbox you buy (ke70 are most common) the shifter position is different between the different model corolla's.. If you buy a ke70 5 speed you'll need to cut the shifter hole a little futher back in your trans tunnel Report
June 14, 201214 yr Author comment_609796 wow thanks for the reply mate, really appreciate it. also are the 5k engines hard to come across? ive been looking online and having a look on jap import sites and things. are they the best places to buy? Report
June 14, 201214 yr Author comment_609797 and also how would you go using a corona 5speed gearbox? Report
June 14, 201214 yr comment_609798 Probably not too many on import sites I think they came out in a liteace van? Report
June 14, 201214 yr Author comment_609799 ah right, so i guess wreckers and things like that? just wait until one shows up... Report
June 14, 201214 yr comment_609801 can't use a corona gearbox. You can only use the KE series corolla gearboxes, or a T50 ae86 gearbox with a rareish K-T bellhousing, which would cost you about 600 for the box and bellhousing. Report
June 14, 201214 yr Author comment_609803 Alright, yeah fair enough i guess i will just keep looking around until a KE series box pops up. cheers Report
July 25, 201214 yr Author comment_617601 Back again, got myself a nice little k50 gearbox now just waiting for a 5k WTB 5k!! anyone know of any around? haha cheers Report
July 25, 201214 yr comment_617602 Just bore your 4K out to take 5K flat-top pistons. Get your cam ground, buy some extractors and fit a Weber 32/36 or twin SUs. Its been done successfully and there are posts on here about it, and if you read filfredericks topic about his twincam 4K you'll see he took it out to 1600cc. http://www.rollaclub.com/board/topic/51097-4k-twin-cam/page__p__522189#entry522189 Report
July 26, 201214 yr Author comment_617840 Awesome man!! yeah upgrading the 4k would eliminate the whole p plate situation and engine numbers would match up. Do you think it would cost roughly the same price to upgrade the 4k as it would to replace it with a 5k? cheers Report
