March 28, 200422 yr comment_7090 Lately my car has been having a few heat issues when driving, normally it used to sit just above the 1/3 way mark, lately its been hitting half way and jumping to the last mark on the guage before the overheating mark. Replaced the thermostat today and it still did the same thing going up the highway, the guage is all over the place, anyone had temperature troubles with a 4K-C before? any suggestions as to what it might be? had the engine apart 6 months ago and the head gasket was changed then, only other thing I can think of is to try torque the head down a bit more... (suspect it has been chewing some water lately so i'm going to have to keep my eye on it) Report
March 28, 200422 yr comment_7100 Could be your coolant, coolant does break down after awhile. Could also be your sender, I know that my sender is a bit spaz... Or even possibly your gauge. Report
March 28, 200422 yr Author comment_7101 Think my next plan is to rape the sender off my other block, then if that doesn't fix it change the temp guage unit out of my other dash cluster. Took it to nicks and back, still goes up but not as high as this afternoon, gave it a thrashing on the way back and it doesn't appear as though it wants to overheat.. weird :dry: Report
March 28, 200422 yr comment_7105 u got ure eye on another motor? maybe this 1 is getting jelious? - you know how toyotas are :P ! Report
March 29, 200422 yr comment_7135 i'd be thinking the guage is on the fritz.. all the corolla's i've had all had guage problems of some sort... one of the things that seems to go wrong on them all (ke70s at least) Report
March 30, 200422 yr comment_7163 my fuel gauge is like that......kinda.....its soooo bloody slow in getting to its right point.....i have to drive at least for 5 -10mins before i get a proper reading.....i'm thinking about changing the gauge.....or trying to find the fuel sender unit Report
March 30, 200422 yr Author comment_7181 It had been working fine for years, but all of a sudden now its all over the place, weird.. seems to be very moody :P Report
March 30, 200422 yr comment_7185 if you have a spare temp gauge or any 1 u know has 1 -borrow it for a few hours, connect it up and see what happens... Maybe the conection at the back of the dial has come loose - u just got the tacko fixed, so I'm assuming they had to do somting with the wiring around that area lol Report
