September 3, 201214 yr comment_624881 Hello all Has anyone used one of the hot spark ignition kits to convert front their points to breaker less ignition? Also what one did u use? Seems pretty good if it works Report
September 3, 201214 yr comment_624890 I didn't see a Toyota list on their website... I suppose they fit the Bosch dizzys almost universally. So you need to buy an Ebay kit for $70odd and a coil for the same. One of the Alfa forums said they were being sold by the agents at $300! How good is your dizzy do you reckon? A new dizzy with electronic ignition is only $130 and uses the coil you have. Report
September 4, 201214 yr comment_624943 http://www.Hot-Spark...istributors.htm no dice for bosch distributors. Ive been tossing up whether to get one for my dizzy but the points have held up so well. They are 60$ + 30$ postage US coins. Edited September 4, 201214 yr by GJM85 Report
September 4, 201214 yr Author comment_624959 Hey altez where are they for 130? I finally got an answer back and they said one of their kits should fit, tis about $80 delivered Report
September 4, 201214 yr comment_624968 KEMotorsports sell them, or used to. He's a site sponsor on here. They're new 5K units out of some industrial motor like a forkhoist I reckon, something that keeps on going so they carry new parts. Report
September 4, 201214 yr comment_624978 KEMotorsports sell them, or used to. He's a site sponsor on here. They're new 5K units out of some industrial motor like a forkhoist I reckon, something that keeps on going so they carry new parts. This is what I'd do. Then read the part of altezzaclub's ke70 thread where he explains how to check the advance curve. I'd buy a new Bosch gt40 coil that does not run the ballast resistor. They aren't expensive and what are designed to run on an electronic dizzy. I've made 100rwkw out of my supercharged 5k with a Bosch electronic dizzy and a gt40 coil. Never had an issue. Report
September 4, 201214 yr Author comment_625057 Can u run a MSD 6A CDI module off the 5k dizzy at all? Also is there any contact info? Edited September 4, 201214 yr by Dust03 Report
September 4, 201214 yr Author comment_625062 Also might still give this hot spark group a try when I get my next bonus, just to see if it fits and if all works well maybe we could organise a group buy as its like $30 shipping alone, so may be able to sort something out with em Report
September 4, 201214 yr comment_625077 Can u run a MSD 6A CDI module off the 5k dizzy at all?Also is there any contact info? 5K dizzy is self-contained electronic, already CDI, & it comes brand-new so the shafts are not worn. Try the Hotspark anyway, it will be good to get reliable information on it for everyone. Report
September 5, 201214 yr Author comment_625083 Its settled then Also pretty sure the 5k dizzy isn't cdi just inductive Report
September 5, 201214 yr comment_625093 It probably is, just not in the uber flame throwing fashion that you're thinking. I've read a reasonable amount that seems to indicate these sorts of kits generally won't make a heap of difference if the rest of the system is in good order. I think the point altezza made about not having a shagged dizzy to start with is very valid. Report
September 5, 201214 yr comment_625179 Electronic distributors use hall effect sensors (magnetic sensors) to trigger spark. They are an inductive ignition system which provide low voltage high current spark just as the break points ones do. No CDI in there. The Hot Spark replaces breaker points with a hall effect sensor when an electronic dizzy is not available. Report
September 5, 201214 yr comment_625267 To me CDI is the name used for the first transistorised ignition systems back in the 1970s. Surely the stock ignitions are all capacitor discharge units, they fire the coil when the power stored in the capacitor (condensor) discharges. The biggest change was to get a unit that let the ponts act as a low-current switch to tell the transistorised setup to fire the coil. The low current through the ponts stopped them pitting and burning from the sparking, and the transistors discharged the capacitor's high current to work the coil. The Hall effect sensor went the next step and replaced the points as the trigger, but somehow there must still be a system of pushing either a 12V high current, or high voltage low current power surge through the coil. So when we're talking CDI, which part of which system are they using? Report
September 6, 201214 yr comment_625276 That was kind of what I'm referring to. But I'll concede that there doesn't seem to be much in the way of capacitors in a lot of stock style hall effect ignitions, the transistors are simply amplifying. I was thinking more about the Bosch HEI setups which I have when referring to electronic which are supposed to have a pretty impressive output. I still can't find any info to indicate that they carry a capacitor though. Report
