September 13, 201214 yr comment_626589 Hi guys, I recently bought a KE11 and I decided to treat it to new plugs, leads, distributor cap, rotor and points. The problem i encountered was the distributor cap is completely wrong. It said on the packet that it suits "Corolla 1967-1975 - all models" but as you can see from my photo, the one from my car is much larger than the one i bought. What have I done wrong? If the cap is wrong, then I assume the rotor and points will also be wrong... is that right? The part number for the cap that I bought is Bosch GD516 Thanks in advance, Simon. Report
September 13, 201214 yr comment_626654 the new cap might have bosch number, but its for a nippendenso dist. you have bosch dist in your ke-11 take old cap with you. get one the same then get points and rotor to suit. cheers mick Report
September 13, 201214 yr Author comment_626670 Thanks Mick... Any idea of part numbers or resources for finding them out? I furiously Googled at lunchtime today with no luck. It's actually my friend who is ordering these bits for me through his work. I won't have the dizzy cap in my possession again until the weekend. :/ Report
September 13, 201214 yr comment_626675 The problem is there are a couple of caps as there are a two K engined Bosch distributors. KE20/30 3K cap is a GB708 rotor GB73 points GB534 condensor GB815 KE55 4K cap is a GB820 rotor GB787 points GB534 condensor GB815 The D in the part number refers to Denso, B to Bosch Edit: I should note, my source is the Bosch Aftermarket catalogue dated 2007 Edited September 13, 201214 yr by parrot Report
September 13, 201214 yr Author comment_626677 Thanks guys. This is a 3K in a 1970 KE11 if it makes any difference. Looks like i'll need to go collect the bits from my mate and take a trip to Bursons. Report
September 13, 201214 yr comment_626681 You can't assume that the engine or distributor are original to the car. I believe all KE1x's would have had a Denso distributor originally. Likely you have an engine from a later KE20 or 30 variant fitted, but equally possible the dizzy has been changed at some point. Worse case scenario, you get the wrong one and have to take it back. Report
September 15, 201214 yr Author comment_626908 Does anyone know why things like distributor caps and rotors don't have part numbers stamped on them? It would take away all guesswork and make a lot of sense. After my trip to Bursons i'm still not sure which part i need. They will need to order them in specially so i can't hold them next to each other for comparison. Report
September 15, 201214 yr comment_626911 Can you find a part number on the distributor? That may help someone identify it for you Report
September 15, 201214 yr Author comment_626912 I had a quick look when i took the photo. If there is a number, it wasn't immediately obvious. I will have another closer look tomorrow. Also note that the rotor fitted to the dizzy in the photo is the incorrect part (the Nippon Denso one)... so try to ignore that. I put it on before i realised i had the wrong parts. Report
September 16, 201214 yr Author comment_627085 I found some identifying numbers on the distributor.... 9 230 062 411 U-PFU4 T 507 19.003 From my research I'm thinking it's probably a KE55 or KE70 distributor. For some reason i can't find any info on the net, despite having part numbers and everything. The closest i got was this document ... http://dualfuel.net.... ADOCATALOG.pdf I also took a good photo of the cap and rotor. Edited September 16, 201214 yr by KE11 Report
September 16, 201214 yr comment_627092 order one for a ke70 - as far as i know, only the bosch distributor (which you appear to have) came in the ke70. I've never seen (an original fitment) nippondenso distributor in a ke70. if the bosch book isn't helpful, use the champion book. I can't imagine why bosch wouldn't have the right numbers in their book considering they make the distributor! Robert. Report
September 16, 201214 yr Author comment_627098 Thanks Robert, I think I will do that. However, as parrot pointed out, there is more than one type of Bosch distributor it could be. In this case I think you're right though, because it looks like a KE55 dizzy which I'm told is the same as KE70. Edited September 16, 201214 yr by KE11 Report
September 20, 201214 yr Author comment_627835 I thought i'd mention that i discovered the distributor is in fact a KE30 distributor. I phoned Bosch and quoted the "9 230 062 411" number and KE30 is what it came up as.... I therefore bought a GB708 cap, GB73 rotor and GB543 points and they fit fine despite the rotor looking quite different and the cap being black instead of red. Thanks everyone for the suggestions and assistance. Report
