October 4, 201213 yr comment_630182 Hey all, Have seen a few people looking but not much else. I'm chasing a mini spool for the Borg Warner 68 in my ke55. Any ideas where to look?? Have had no luck on ebay. Plus any idea how many splines the axles would be? Cheers. Report
October 10, 201213 yr comment_631189 But in all seriousness the model 68 BW is not a common diff to be mini spooled.. I don't think they even make spools for anything other than the r31 BW. Time for the MIG welder to come out and weld the spider gears up like so... Report
October 10, 201213 yr comment_631190 I don't think they even make spools for anything other than the r31 BW ^ This See if you can source a diff that has already been locked/welded, then you can use your open diff as a spare :y: In case you ever get a run in with the :fuzz:, you'll have more options Edit: Then again, any form of permanently locking a differential in a road car isn't encouraged or endorsed by myself and is especially frowned upon by the law. Edited October 10, 201213 yr by LongJohnSilver Report
October 10, 201213 yr Author comment_631216 ^ This See if you can source a diff that has already been locked/welded, then you can use your open diff as a spare :y: In case you ever get a run in with the :fuzz:, you'll have more options Edit: Then again, any form of permanently locking a differential in a road car isn't encouraged or endorsed by myself and is especially frowned upon by the law. yeah i know will not be used on road much. mostly khanacross and motorkhana. don't want to spend the money on a diff conversion yet and lil bit concerned bout welding..... mayb the only way to do it. Cheers mate Edited October 10, 201213 yr by NinjaMekanik Report
October 10, 201213 yr Author comment_631217 Time for the MIG welder to come out and weld the spider gears up like so... 1. Not the spider gears 2. I'm not an idiot 3. already saw it on another thread haha :thumbsup: Pretty funny though ....... Report
October 11, 201213 yr Author comment_631240 ^^ Would be keen however in Ipswich. Would you be able to ship and how much? EDIT: if its only the centre its not as much of an issue as i was thinking ... so yes keen :) Edited October 11, 201213 yr by NinjaMekanik Report
