October 10, 201214 yr comment_631127 Hey guys. Finally got the 5k into my ke55 that i had been working on for a while (the conversion). It is running, and drives- but not well and makes a crazy noise. The noise is like a fast tapping/ rattling noise coming from some where in the middle of the motor. Could anyone suggest what the noise may be, and how sinister it may be? I built the motor myself, it has: -5k block with 5k rods, lifter etc (hydro) -5k SHALLOW DISH pistons -5k DEEP DISH head (standard) -4k valves/ springs (standard) -25/65 270* cam grind -rollamaster timing chain kit -4k ancillaries -shimmed oil pump As far as i can guess the noise may be piston rattling or something because of the huge compression. Any other ideas? Also, the motor does not easily rev far past 4000 revs, not that i have been game to push it. I have the deep dish pistons here but i was initially going to use a 4k head, hence going with shallow dish pistons, and want to avoid swapping them out! Report
October 10, 201214 yr Author comment_631157 I'll have another listen but that sounds pretty darn close- what was happening there???! Report
October 10, 201214 yr comment_631162 Didnt take measuring the bore seriously and put standard pistons in an 20 thou over bore (0.5mm). From memory my bore was 81.2mm where standard was 80.5mm. It doesnt sound like a lot but it works out as 20cc per cylinder. My 5k is actually 1566cc. As for the reving issue your going to want to look at cam timing. I had the same cam as you and it was also a tooth out. Edited October 10, 201214 yr by GJM85 Report
October 10, 201214 yr Author comment_631172 Oah ouch. I think I'll have to take the motor back out again and change the pistons then. This gives me a chance to sort the compression out and a little leak in my sump gasket as well as check the cam timing again. Did you have a good method for being sure of the timing? I took the chain off, found and marked the opposite links and lined them up with the timing marks, thinking that opposite is where the marks were meant to be? Report
October 11, 201214 yr comment_631288 being a regrind cam, google "how to dial a cam in", you could either do it yourself by purchaseing a dial (ebay special), or take it to an engine reconditioners. Hope that helps. Report
October 11, 201214 yr comment_631291 I took the donk apart. I found that the timing marks weren't perfectly aligned when I put a straight line across the cam, timing marks and crank centres. Even if your cam does need dialing in you can still align these marks and be well off. Report
October 13, 201213 yr comment_631528 Just wondering how much power your expecting out of that 5k setup? Report
