November 8, 201213 yr comment_635524 I know there is a few threads on this but none seem to be the same as the issues I'm having. So every light in the entire car(this includes parkers) works but the headlights. none of the wires coming of the stalk are broken which seems to be the common issue. I've tried swapping the relay with others that I know work. There is no blown fuses. The problem started after my 4age conversion. I did unbolt all the wires and stuff from the drivers side guard( wiper motor and etc) Are any of the headlight components? Earth or something? Edited November 8, 201213 yr by It's_AUDM_Yo Report
November 8, 201213 yr comment_635529 There is a few big earths down the front somewhere that are usually bolted to chassis somewhere, i recall one of them having somethign to do with headlights. i un did mine once, forgot to put it back on, crazy things happened. Grab a wiring diagram for the headlights, should be able to figure it out from that? Report
November 8, 201213 yr comment_635530 Try unplugging and checking the fuse able link near the battery that was the problem with my T18. Report
November 8, 201213 yr Author comment_635544 There is a few big earths down the front somewhere that are usually bolted to chassis somewhere, i recall one of them having somethign to do with headlights. i un did mine once, forgot to put it back on, crazy things happened. Grab a wiring diagram for the headlights, should be able to figure it out from that? I have a diagram but it doesn't say where anything is, which is half my problem. Are these earths on the rad support? Try unplugging and checking the fuse able link near the battery that was the problem with my T18. My battery is in the boot and runs the ae92 which then does the ke70 loom. So its not there. Report
November 8, 201213 yr comment_635567 Check what your missing at the headlamp plug with a circuit tester or meter...rule out whether its an earth problem or power probem...go from there..:) Report
November 8, 201213 yr Author comment_635575 0.1v at each pin So i'm guessing its probably an earth I just can't find the bastards Edited November 8, 201213 yr by It's_AUDM_Yo Report
November 8, 201213 yr comment_635577 Lol, how is it that you managed to wire your engine conversion but you cannot figure this out? :harhar: Edited November 8, 201213 yr by rian Report
November 8, 201213 yr comment_635579 There is a ground off the dimmer/headlamp switch (white/black). And a ground off the instrument cluster (white/black) According to my wiring diagram those are the only 2 grounds off the headlight circuit. Report
November 8, 201213 yr Author comment_635587 Lol, how is it that you managed to wire your engine conversion but you cannot figure this out? :harhar: I dunno, I've gotten seriously good at wiring on 4age's now probably cause mine was so ʞ©$ɟed. Its probably cause I can't find the shit for the lights everything is just scattered across the car. There is a ground off the dimmer/headlamp switch (white/black). And a ground off the instrument cluster (white/black) According to my wiring diagram those are the only 2 grounds off the headlight circuit. Do you know where they are by chance? Report
November 9, 201213 yr Author comment_635673 Alright, Problem solved lost intrest in fixing them so I just re-wired them from scratch. Report
