All 4AGEs will "fit"
The AE86 and AA63 are the only car that has the intake manifold facing the correct way.
All other 4AGEs need their manifolds cut'n'shut and need rwd water outlets or modified ones.
So 1.6l twin cam Corolla's from AE82-AE110
edit: from wikipedia
Edited by It's_AUDM_Yo
ae101 has ITB's, do don't need to cut and shut manifold, but is the more expensive way of going 4age, if you want an engine upgrade tell us how much money you have to spend? You should allow around 5K to do the engine swap if you can do it yourself. Some people have done it cheaper, others have cost more so don't bother telling me you got an engine for 1k and that was all you had to buy.
Then allow another about another 2-3k for suspension and brake upgrades.
I've seen a ae101 silvertop motor if I was to get it would it have to be cut and shut? If so how much does that cost?
If you want to keep an airbox and plenum then you might need to cut it up a bit. Velocity stacks and slip on filters look alot cooler. And sound awesome.
Silvertops are AFM though so if you want to run no airbox, you'll need to go aftermarket ECU aswell.
20v's are more expensive for sure but do make more power from factory. I think if you plan on spending a bit of money on a 16v, you may aswell go 20v to start with. Gain that extra power from the get go.
People will say a 16v has more potential but within a realistic budget, I think 20v is the go.
Edited by Willis
Fairly sure you can run a silvertop with open trumpets if you use a blacktop ECU, MAP sensor and a few other things, cheaper/more reliable than aftermareket
Heard of people doing that before. If I had the money to spare, I'd go aftermarket for sure. Get a good tune, go COP. That's another option though.
Edit: Or start with a blacktop
Edited by Willis
