Ke70 Manual Conversion From Ae71 Man
ohk so ive got an auto 1983 3 speed and i also have a 84 manual corolla 1.6 ltr and could someone please tell me the exact steps n stuff i would need to do to change the 82 to a manual, please help?
They are completely different, you will need to swap engines, cross member, the 1.6 has a hydraulic clutch, tail shaft etc.
So basically all the running gear. Why not use the manual car?
EDIT: Unless you get a K-T gearbox bellhousing.
Edited by B.L.Z.BUB
Its worth it-
Swap motor & gearbox,crossmember, pedal box, clutch hydraulics and sort the taiolshaft & exhaust, and then you're ready to convert the 4AC into a 4AGE later. The 1.6 gear adds to the price when you sell it, it makes it easier for anyone else to do a 4AGE conversion.
