xmoht Posted April 26, 2013 Report Posted April 26, 2013 Hi everyone, 1984 Corolla KE70, stock engine and everything, battery less than one year old. No issues but shortly after installing a remote central locking kit the battery kept dying. Cheap aftermarket kit mind you, and I wired the power directly to the battery in the engine bay. Is the likely cause of the drain the remote central locking? If so - Is it the continual drain caused by the remote aspect always sensing? - Could it be a problem with the unit itself? - Is it the poor wiring? Should it be connected to something else? - Would a larger battery compensate for the drain if it is caused by the remote sensing? If anyone can provide me with some advice it would be really appreciated. Setting up a new KE70 and transferring some parts over so I want to do a good job of it this time rather than rushing it. :D Quote
B.L.Z.BUB Posted April 26, 2013 Report Posted April 26, 2013 I have a nasty budget central system hard wired to the battery also. Havent had a battery drain issue. Sure its wired properly? Quote
ke70dave Posted April 26, 2013 Report Posted April 26, 2013 Lol at the quote in your signature, i remember that guy. I think the system will be "looking" for a signal, which will use a bit of power, but it should be miniscule. if you disconnect it does it stop draining the battery? Use a multi meter to meausre the current draw of the unit? if one of the actuators is installed incorrectly, and it is sitting half way through its stroke, maybe its trying to push/pull the lock continuasly? i dunno, just a guess. 1 Quote
xmoht Posted April 26, 2013 Author Report Posted April 26, 2013 (edited) Thanks for the replies guys. It looked wired properly, actuators worked really well. I guess I'll just have to put it in the new car, run a multimeter over it and see what happens. Any suggestions on where the wire the power, somewhere inside the cabin? Yours is connected through the firewall directly to the battery terminal beezlebub? Also I laugh every time I read AE92Nova's posts, particularly enjoy 'could/will drift away from a police chase to safety'. Edited April 26, 2013 by xmoht Quote
B.L.Z.BUB Posted April 26, 2013 Report Posted April 26, 2013 I had an amp cable from the previous owner under my drivers seat so I mounted the receiver there under the seat rail box. So its hard wired to the battery. I never even got wiring instructions with mine, I had to guess it the kit was that cheap, still going after 3 years though. 1 Quote
