4Age Carb Dizzy Mod
Hi all,
Ok, so I'm doing a carb conversion on my 4AGE, now i have done a bit of reading on what to do with the distributor, now i have read that you can use the guts out of a 4kc as such.
I would just like to know exactly how to modify the dizzy, has anyone got any pics and a write up??
Also how far of would a 4AC dizzy be from using??
hmm??
Thanks all =D
The dizzy you can use is k engine electronic from a 5k .But you have to make a spacer plate to move it out,as the shaft is a lot longer on a k dizzy .
You also have to use your 4age drive gear.
Pm trd70 on here regarding the spacer.
The 4ac would fit but it turns the wrong way,which may or may not be changed i started to look in to this but have bigger projects atm.
Third choice is a hyperpak from nz use to be on ebay for about $280 .These work well with your factory dizzy.
rob
What about a crowd like these guys - http://www.performanceignition.com.au/home
For a cost of course, I'm sure they could make one up with a set of point's and a vacuum advance to suit your needs. I'm not certain but it might be worth a look. I know that's the path I'd take if I ever go with a Carb 4Age.
