Mounting Ke25 Fender Mirrors !!
I've wondered this for a KE10 myself...
OK, bear with me here.
The distance between the front 9mm diameter hole and the rear 6mm hole is 40mm centre to centre
The front hole is 55mm from the inner edge of the guard to centre hole(i.e. the edge that sits next to the bonnet when closed)
The rear hole is 56mm from the inner edge of the guard to centre hole.
For placement of the front 9mm hole do as follows. Looking at the bolt holes that mount the guard to the body. The distance between the second mounting hole from the front to the third mounting hole is 185mm centre to centre. If you measure back 95 mm from the second (front) hole, and draw a 90 degree line with pencil, that is the location of the centre of the front hole.
EDIT: Make sure you measure twice and drill once, ONLY after you satisfy yourself the placement of holes tallies with the photo's! No responsibility taken etc
Edited by parrot
There should be a 'notch' under the guard that the spring cup sits in perfectly. All my early Toyota's have it. That's the exact position for original style fender mirrors.
Thanks heaps parrot and b.l.z bub. Appreciate it ! Let you guys know how I go.... Ill have a look and see if I can see anything ra28gt. Thanks again !!!
Mine has the holes from factory the inside of the guard has some sort of tar patch or something on the inside and then filled over with bog take your guard off and have a look the holes might be there before you go drilling
