November 18, 201313 yr comment_672054 Help me out here! I can't seem to find my answer... Does the alternator, bracket and swing arm from a 4afe bolt onto a 4agze? I don't have a bracket on my ZE and am doing a rwd turbo conversion. I was thinking about buying a ZE alt and A/C bracket but apparently the alternator hits the sway bar on the AE71/86. Any help is appreciated or a link to the page would be good! Thanks Report
November 18, 201313 yr comment_672056 I just put a stock GZE in mine, the alt is nowhere near the swaybar. Can see how high it is in this pic. The A/C might hit if it was still on there. Report
November 19, 201313 yr Author comment_672129 with the mr2 ZE motor the alternator sits up higher then i guess? Maybe I should just source a ae82 big port set up, I think that might be easier than trying to make a ae92 low mount alternator fit/clear the sway bar? any info on this would be great as I'm looking at buying some stuff from littleredspirit that is low mount from said ae92. If anyone can tell me if it clears the sway bar that would be great! Report
November 19, 201313 yr comment_672131 Ah ok yours is like this? Bigport alt is on the Supercharger side. I wonder if you could use a 4-AC alt mount? Edited November 19, 201313 yr by B.L.Z.BUB Report
November 19, 201313 yr Author comment_672140 Ah yes 4ac might be the go, but I would still like to keep the ac as well so if it can fit like in the pic that would be perfect, but yeah I like what your coming up with! Report
November 24, 201312 yr comment_672393 Bit late to the party, I had a 4AFE sitting here a couple of weeks ago. Aircon sits low on the exhaust side of the motor with alternator above. Power steering pump on inlet side. If you're using a 4AGZE motor and want to keep the power steering, you'll have to run the Aircon, just to retain the idler pulley for driving the power steering pump. Report
November 26, 201312 yr Author comment_672560 It's going into an ae71... so no need for p/s :( anyway I would like to run ac still as it already has everything in the car, so I'm guessing it would be easier to use ae82 4age stuff? i'll be using the fwd water pump so I would think it would be easy enough to use/bolt on. Report
November 27, 201312 yr Author comment_672622 so while we're on this, if I use an AE82 4age A/C bracket and pump would that hit the sway bar? And has anyone used a 4ac A/C bracket and pump with a different pulley? just because I have one already and would use it if I could as its still nice and cold, any helpful info is appreciated! Report
