Radiator For 16V 4Age Ke70.
Hey guys, I was just wondering what radiator I should run in my KE70 for my 16v 4age conversion? I've read ae86 and ae71, but just want to hear what others have done.
Cheers mate that's what I was gonna end up doing. So the inlet and outlet position are alright?
The top hose position is fine, but the bottom hose is on the wrong side. You can still easily make it work, you will just have a really long bottom hose and it will probably require a bracket to keep it up off the swaybar.
Alternatively you can use an AE71, AE86 or even a Hyundai Exel radiator.
Cheers mate thinking about going ae71 radiator then but what fan can you use? Is there an engine driven fan that will fit the 4age?
are you using the FWD or RWD pump?
I'm using an AE82 thermo fan/shroud combo on an AE71 radiator in my KE70, I just made up some mounts and bolted it on. The shroud covers about 3/4 of the radiator.
Or you could just mount a universal thermo fan, which is super easy.
I'm pretty sure there is an engine driven fan for 4AGEs but they would be hard to find as they would only have come on the RWD 4AGEs.
Edited by rian
Yeah sorry I didn't mention this is a rwd 4age. I was gonna get an ae71 radiator and use the thermofan I have.
