July 19, 201412 yr comment_685741 As title says, something along the line is meaning my battery isn't charging. It will drive with a jump start, but only reads around 9 on the multimeter. Brand new alternator Brand new battery Brand new terminals and wiring Brand new regulator. Yet its still doing it. This is on my 4k KE70 Panel van. Any help would be massively appreciated. Report
July 19, 201412 yr comment_685742 Internally or externally regulated? The alternator needs an 'on' signal to start charging, check its getting switched 12v. Report
July 19, 201412 yr comment_685754 Sounds like a wiring/connection issue. If all the parts in the charging system have been replaced it can't be much else. Does the battery light come on with the key on then go out when running, not come on at all, or stay on all the time? Report
