peterd Posted August 9, 2014 Report Share Posted August 9, 2014 (edited) Hi. I'm a new guy. I've found myself a great 90% restored ke35 and I'm just getting it ready to be registered. I need to connect the heater hoses and don't know which way round to connect the hoses. I don't know whether the top tube on the firewall is an outlet or inlet. Hopefully the heater box is ok and I don't end up with a car full of radiator water. I'd appreciate any help. Edited August 9, 2014 by peterd Quote Link to comment Share on other sites More sharing options...
Banjo Posted August 9, 2014 Report Share Posted August 9, 2014 (edited) Hi Peter, Welcome aboard ! Try reading this post. It may help. Not too many subjects or problems that haven't been tackled on here before. http://www.rollaclub...heater-problem/ I'll have a look at KE30 setup when I'm in the garage. I assume the heater box inlet on the firewall with the heater tap on it; is the inlet from the hot side of the water pump, which is the LHS, looking at the engine from the front. The heater box point on the firewall with no tap, would be the return to the same side of the water pump, where the bottom radiator hose is connected. Cheers Banjo Edited August 9, 2014 by Banjo Quote Link to comment Share on other sites More sharing options...
peterd Posted August 9, 2014 Author Report Share Posted August 9, 2014 Thanks Banjo I had a think about it and figured it didn't matter which way I connected it. As it turned out, the heater wasn't connected for the obvious reason. I ended up with a car full of coolant. Bugger! I'm trying not get the bastard heater box out of the car now but its jammed. I'm going to sleep on this one. Quote Link to comment Share on other sites More sharing options...
DZach23 Posted August 9, 2014 Report Share Posted August 9, 2014 The top tube on the firewall goes to the passenger side lower goes to the drivers side Quote Link to comment Share on other sites More sharing options...
peterd Posted August 10, 2014 Author Report Share Posted August 10, 2014 Well I finally got the heater box out and found a big split in the inlet pipe. The core seems fine. Gregory's Workshop manual says that to remove the heater box, you just disconnect it, remove 4 bolts and remove it. The missing part was that you need to remove the dash first. To remove the dash, you also need to drop the steering wheel to get to the bolt that's directly above the steering column. Hopefully I can get the whole thing back together again. Quote Link to comment Share on other sites More sharing options...
Banjo Posted August 10, 2014 Report Share Posted August 10, 2014 Hi Peter, Real pain getting a heater core out & then back in. Been there; done that ! It's one of those things you only do once hopefully. Cheers Banjo Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted August 11, 2014 Report Share Posted August 11, 2014 You can easily do it with out removing the whole dash, just remove the heater control panel and you can wiggle the box out. Quote Link to comment Share on other sites More sharing options...
peterd Posted August 15, 2014 Author Report Share Posted August 15, 2014 Can anyone help me with either photos are parts listing for the heater hose configuration for a 4k motor in a ke35? I've got the basic idea from google images but the shops aren't interested in helping me without a parts listing. Only radiator hoses for a 4k come up on their computers. Thanks heaps. Quote Link to comment Share on other sites More sharing options...
