September 5, 201412 yr comment_687986 Hey I've been told to use cut as springs for my 30 just wondering what would be best and what model ss if ss is correct just want something a little stiffer in the front end before I go getting a away bar or anything Report
September 5, 201412 yr comment_687991 Cut springs, not really a good idea as it isn't legal...... Report
September 5, 201412 yr comment_687992 Best bet is King Springs as they will lower your car while still being captive. Any lower and the springs may become unseated. To avoid this you'll need shorter shocks and there just inst any good selection of shocks for the stock strut. Your best bet would be a strut upgrade, AE86, Celica or even TE72. With all of these you will get a brake upgrade at the same time. Cut springs are terrible. Report
September 5, 201412 yr comment_687993 The other thing to consider is if you up the spring rate you must up the shock absorber as well. Report
September 6, 201412 yr Author comment_688019 Depends what you really want to do with it as if your making big power/torque you want to soften the rears as to keep as much traction as possible Report
September 6, 201412 yr Author comment_688021 But see I just want a cheapo ah harder spring front springs Report
