September 28, 201412 yr comment_688875 hi guys, got a 5a-fe lying around and decided to use it on my ke50. got 2 problems however. The distributor and water inlet and outlet will be at the back on a FR mounting. Any one here swapped a FF motor in a FR car pls who can help? Report
October 2, 201412 yr comment_689032 Hmmm ke50, cool and rare car. Kinda like an early version of a T18 in some ways... I'm going to try and be helpful here, I would recommend you use a motor that someone has successfully swapped already, I don't think 5a-fe's are a common swap for a number of good reasons. Plenty of swaps around that are a better idea. People have converted fwd 4age's to rwd 4age's but it takes a few bits to get it done and its not cheap... Report
October 2, 201412 yr comment_689033 Read through this, some info on the toyota A series that could be of use http://www.toyotanat...-swap-help.html Also wiki http://en.wikipedia....Toyota_A_engine for the hybrid 7age build which is a combination of 4age with 7afe. Edited October 2, 201412 yr by styler Report
October 2, 201412 yr Author comment_689034 to be honest, i am only using the 5a-fe as I already have it after buying it by mistake for my daily 1998 starlet(mistaking it for a 5e-fe!!) I tried unsuccessfully selling it to buy a 5k, so I decided to use it instead of leaving it lying around. I already have a T50 for it(although without shifter). The engine originally had an auto tranny, so I will need a flywheel and clutch kit. That's not the main problem. what is worrying me is dizzy and water in/out elbows relocation. Even if i did find a 4a-ge, in all probability it would have been a fwd version, so the nightmare wouldn' t have been less grevious. the guy in the link you gave me had something even more complicated by using 4wd transmission!!!! at least I'm not into that. btw what is a T18? Report
October 2, 201412 yr comment_689043 T18s are the two-door fastback KE70s. 'T" designation from their T-series motors instead of the "K". If I were you I would weld up a water fitting out of steel sheet without too much trouble, but the dizzy will need converting to electronic. That means buying some aftermarket computer, fitting the cam sensor part to the dizzy base only, so it shortens the dizzy. The dizzy cap and rotor get replaced by the wasted spark system that fires two cylindes at once. More advanced (and expensive) would be to mount a crank sensor on the pulley or flywheel and replace the dizzy completely. So price up the cost of customising mounts, radiator & brake system changes if needed, ECU & coils, machining, driveshaft and add a couple of thousand dollars for problems you can't see yet and decide if it is worth trying to resurrect that motor or just throw it away. Report
October 2, 201412 yr comment_689045 "i am only using the 5a-fe as I already have it" - This is generally not the best reason to use an engine for a conversion... The cash required to make the 5afe work will be more than what the 5afe owes you. Report
October 3, 201412 yr Author comment_689051 The car was bought without engine and transmission, tailshaft, radiator, battery etc.. and having stood abandoned for sone time. brake and suspension systems need upgrading too. so since I am practically starting from scratch all the above needs to be donem would have been easier of coursrle throwing a 4 0r 5k but a dohc motor is a better starting point. even with the k motor, I would still have spent €€€ on upgrades. Report
October 4, 201412 yr comment_689082 Ah- so it is not as bad as it seemed. Chase up the conversions of dizzys to electronics, I can't think of any on Rollaclub that have done what I saw, but you just use the dizzy base to keep the rotating cam and fit a wheel to that. You can use a magnetic sensor or an optic one I expect, anything that sends a signal to the computer to fire the coils. Report
October 9, 201412 yr comment_689257 Maybe just do up the k motor, will be fun... and less expensive... food for thought anyway! Report
