Nexus4agte Posted March 29, 2015 Report Posted March 29, 2015 My 4age redtop has been sitting for about 3 years, got it running but its running on 3 cylinders, changed spark plugs and leads still doing it??! has abit of stale gas in it but didnt think they would be a big issue? gonna clean dizzy tomorrow but if they doesnt work any ideas? cheers Quote
altezzaclub Posted March 29, 2015 Report Posted March 29, 2015 Valve stuck open? (or closed) Do a compression check before getting too carried away. If the dud cylinder has compression it will be fuel or spark. See if the injector will squirt fuel into a cup. Might be the dizzy cap, a crack by that cylinder lead, but there's not much else if you've done plugs and leads. Quote
ke70dave Posted March 29, 2015 Report Posted March 29, 2015 Dirty fuel certainly wont help. Id be looking a blockex injector if you think the fuel is suspect. Quote
oldeskewltoy Posted March 29, 2015 Report Posted March 29, 2015 simple check for injectors if you don't have equipment is swap 2... and see if the problem moves with the injector.... Quote
