Hi guys,apologies as I know its not specifically corolla related so wasnt surte where to put it but I know a few of you have Coronas so I'm hoping someone can give me a dimension from centre to centre of the spring pads on the rear axle of a RT104 Corona? Thanks in advance for any help you can give.Pete
Damn,well that wont work,20mm to short centre to centre,I was sure I was told it would fit. Anyway,would anyone know if the RT80 would be the same as the 104's? I was given a model name that would fit what I wanted exactly but I have forgotten it but I was pretty sure it was a rt80 or rt104, I need 1020mm centres on the spring pad mounts,maybe someone has an idea,being fitted to a non toyota/corona car that has been fitted with a toyo engine..
